Old 04-24-2016, 05:52 PM
Default Re: Fumotec 490
So you have 2 auxiliaries & the hyd quick coupler? Six valves really fill up the back of the model... I thought 5 was bad enough!
Old 04-25-2016, 12:55 PM
calum_scania's Avatar
Correct Joe, quick coupling will be run off the 2 small lines on the outside and I'm planning on purchasing a grab later on this year if and when I get the model up and running. Yes its very tight but all the covers fit without modification just hoping I can squeeze the battery in behind the valves and into the counter weight of i'm going to run into problems
Calum
