I don't recall reading where you added a gas spring, but great idea to take up the slack in the gear back lash to keep the movement tight.
![]() ![]() Whether 3kg or 6kg gas spring, the difference in length of backlash travel will always be the same... might as well leave the 6kg in place.
Yes, true, I just thought the 3kg would be less violent when it engages. It should probably be a pulling spring instead of a pushing spring so that the backlash is only seen when pushing hard with the stick and not when pulling hard. I'll see what I can do about it.
I also found that the set screw was loose, so the backlash is only about half of what you see in the video when the set screw is tight. I have done a few things that I haven't documented here yet. The gas spring on the stick, a gas spring on the bucket, a mount for the CPU (the Raspberry Pi) and angle sensors for the bucket and stick. I'll get those updates up here shortly. :-) Stein :-) |
Added a simple mount for the brain (CPU) of the excavator. At the same time I replaced the Raspberry Pi 2 with the version 3. It's mostly the same, but a little bit quicker and has WiFi and BlueTooth built in.
- Raspberry Pi 3 The mount is very simple. Four self-tapping screws to hold the PCB and then two nylon M4 bolts to hold the mount on the base plate. ![]() ![]() ![]() The audio (engine sound) has its output through that 90-degree 3.5mm jack on the top. ![]() |
Bolting together the arm
The arm sandwich of 3mm aluminum sheets with 3D-printed ABS in the middle is held together by 34 M4 countersunk stainless steel bolts and sleeve nuts. There are different length bolts used throughout the arm: - 23 x 50mm (for the main part) - 5 x 75mm (80mm cut to length) for the stick hub - 4 x 80mm for the stick mount - 2 x 55mm for the stick angle sensor mount Ebay links: - Bolts: http://www.ebay.com/itm/231787670429 - Sleeve nuts: http://www.ebay.com/itm/191771467782 ![]() ![]() |
I added a gas spring from the boom to the stick. I only found the correct length, stroke and force on Aliexpress:
- 6kg (60N) gas spring: http://www.aliexpress.com/snapshot/7601366858.html The sleeves and spacers are cut from 8mm and 12mm stainless steel tubes. The pin is also gotten from Ebay: - 8mm (ID 4mm) tube cut to 13mm length: http://www.ebay.com/itm/121600172085 - 12mm (ID 8mm) tube cut to 4mm legnth: http://www.ebay.com/itm/121762512929 - 8x30mm pin: http://www.ebay.co.uk/itm/121851516316 ![]() ![]() ![]() ![]() |
I also added a gas spring to the bucket, mostly for the visual appearance as the bucket is already way more powerful than it needs to be.
The spacers are made the same way as previously, cut tube to length. Ebay links: - 8mm (ID 6mm) tube cut to 4mm length: http://www.ebay.com/itm/121762445745 - 12mm (ID 8mm) tube cut to 4mm legnth: http://www.ebay.com/itm/121762512929 - 6x30mm pin: http://www.ebay.co.uk/itm/121868709865 - 8x80mm pin: http://www.ebay.com/itm/291511678072 - Eyelets: http://www.ebay.com/itm/151838223022 The lower eyelet is drilled out to 8mm to fit the 8mm pin in the bucket linkage. ![]() ![]() ![]() ![]() ![]() |
