1:1 Your Semi's,Trucks and Equipment Here is a spot to share your 1:1 that you drive and or operate. |
So as long as it keeps raining the cement won't set up in the box? Is the hardener added by the paver machine?
Concrete will setup under water . It's a chemical reaction with water added to the cement .
Thanks for the explanation Lil Giants. I'm always impressed by the techniques and new technology used.
tough break on the weather! Hope it clears up soon. Temps are hovering between -3 to +10 here which is typical Maritime climate. Newfoundland got 50cm or snow last week, they can have it. ![]() |
True, but is the chemical makeup altered per applicable use? How long does the wet batch sit on his trk before he HAS to dump it out? Why stop paving when it's raining when the cement will eventually setup anyway?
Cheers! |
