Old 04-29-2016, 06:32 PM
Yep, that's good advise.There is a flat spot, but I just hadn't tightened it and I only added the left set screw, not the right. Lot's of screws loose at this point, like you say, it gets taken apart all the time when when building and testing like this. I'll get it all tight at the final assembly and add some blue locktite for good measure! :-)
Stein
