Old 04-29-2016, 11:55 PM
Default Re: Something new to rc
Crop checking Wed & Thurs, cooler single digit temps & the soil cool damp, the lentil seed had a root jetting down an inch and another coiled around the seed. Today with warm sunshine, that upper root is starting to go skyward, just a few mm below the soil. Blasted off one tank of spray just before dark & the 2nd one early tomorrow morning. With a magnifying glass, I might be able to see the lentil poke through the ground Sunday afternoon The ground tonite was wet enough that I wasn't making much dust @22mph, but not throwing any mud either... sweeeeet!
Probably Sunday I do 3 tanks of burnoff for the peas, they were seeded a little deeper, grow a little slower.
Normally cleaning out the seed cart, I would auger back into the trk, but metal screw augers are not too friendly to yellow peas, there's always a small percentage of crack every time it goes through metal screw... so I eliminated one unload by dumping directly into bin with the aid of a short hyd belt conveyer.
Then reloaded trk with a different blend of granular fertilizer & the pup with durum... cart is turnkey tomorrow.
Hammer down for the next week... everything goes well, should plant +300ac daily, plus spray 400ac per day... be done durum by next Friday. Then it's a section of brown mustard & 75ac green feed....
