Old 05-10-2016, 04:40 PM
thetractorfan thetractorfan is offline
thetractorfan is on a distinguished road
Default Re: O&K Damitz RH6.6 Big OilPump 750ml
The bigger pump gives a better breakout force. You could probably dig through thick clay or even slightly frozen ground with this machine. Also, better pump gives more torque to the tracks so you can`t get stuck very easy. And you can do so much more if you have auxiliaries because Damitz has everything from orange peel grapples to clamshell buckets. so much better than other RC excavators.
