Old 05-15-2016, 11:03 PM
Rakthi's Avatar
Rakthi Rakthi is offline
Default Re: ScaleART - Assembling a MAN TGX/XL 6x6 tractor & Trailer
Thought about Savoy, have those in the CAPO truck. Played with the idea to get one out of there, but too much work taking the thing apart. Also not sure about the fit and a tad too lazy to check the sizes. Will see how it works out.
Maybe I should just have gone for the non-digital ones. Might order some of those next time. Less to go wrong.
Meanwhile I will adjust the rest of the servos and plug the spare I have in the fuel tank. Start pulling the electrics towards the front etc. That will keep me busy for a bit.
Old 05-18-2016, 12:25 AM
Rakthi's Avatar
Well got the fuel tank off and the servo out. Checked servo, same as the other one. I connected the electric motor of the servo directly to a 5 volt battery, and no go, so seems like the little motor died and not the electronics. So much for the trouble shooting I could do here.
Had a really hard time getting the side covers of the fuel tank. Good thing I didn't glue them as suggested in the manual!
Stuck the spare servo in there, and hooked it all up to the receiver and then switched diff lock on and off a couple of times. This servo seems to be behaving. (Actually should have used receiver/transmitter the first time too.)
Diff unlocked
Locked
Stuck it all in the fuel tank and then locked/unlocked about 40 - 50 times ...
Very tight fit though.
Unlocked
Locked - The nut of the cable holder is almost touching the sides. Thinking of adding 4 or even 5 washers instead of 3, but will have to file some of the ridge to make sure the servo fits then.
I dinged the tank taking it out, so will need a bit of sanding and painting again ...
Tags
man tgx xl, scaleart, trailer
