Old 05-18-2016, 10:52 PM
Cat966c Cat966c is offline
Default Re: Bruder Cat Compactor Coversion
Thanks,
No fancy tricks there. The vibrator motor is wired up just like all of the others. It runs off of an RC switch rather than an esc so it is only on or off.
I'm not positive of what you mean with two motors on one terminal but if you want to run two off of one esc just make your own Y harness. Speaker wire works well for smaller brushed motor hook ups. It can be found everywhere and it's reasonably priced. I use smaller wire on the tiny motors that drive my tarps and operate the blades on these rollers. You asked on the other loader thread about wiring multiple motors to one esc. It's easy, just wire them so that one side of the machines motor connections are +/- and the other is -/+ otherwise it will go in circles. Connect those wires to the +/- coming out of your esc and your good!
Bueno, Bueno, Bueno!!!!!!
THANK YOU!!! That help ALOT.
But I'm not out of the woods yet. Speaking more on wiring small brushed motors: so I just take speaker wire from the hardware store and connect the positive and negative and so on?
And about the rc switch: what's the deal with those? What are they exactly? Does having an esc rather than a switch make the motor have variable speed?
Sorry for the peppering, but I'm soooo close to getting it.
