Old 05-20-2016, 06:41 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Default Re: ScaleART - Assembling a MAN TGX/XL 6x6 tractor & Trailer
Hi Liftmys10, If we could still get the FS 70 MG servos from Robbe it would be a bit easier. Those are about 1mm less wide and 2 mm less high. But sadly enough Robbe had to close the books and the Hitec ones are closest in size for the same torque.
Well nothing a couple of washers and a bit of filing can't take care off.
And filing is the only thing I got around to doing today.
Taking that ridge out should make it possible to get the servo a tad more to the back so there is more than a hair's width of space left when the diff is locked. Bit worried that over time the plastic servo horn will start bending a little under the tension and hit the sides causing more stress on the servo.
Old 05-21-2016, 01:33 AM
Rakthi's Avatar
Filing the ridge worked.
Before clipping the sides back onto the fuel tank, did a quick test set up to finalise the servo settings.
Sides clipped on again and re-installed in position.
Final test
Diff unlocked
Locked
Reattached the little clip I made to push the bowden cable forward to better clear the front propshaft.
Old 03-21-2018, 11:22 AM
Panther F's Avatar
Panther F Panther F is offline
Panther F is on a distinguished road
Very meticulous, detailed images. Looks just like a museum piece.
Old 03-25-2018, 07:40 AM
Tp_hofmann Tp_hofmann is offline
Tp_hofmann is on a distinguished road
Finally the build continues, cant wait to see the updates coming!
Cheers,
Thomas
Tags
man tgx xl, scaleart, trailer
