Old 05-20-2016, 01:28 PM
Northern Farmer's Avatar
Default Re: RC4WD 4200XL models and nomenclature?
Wtf won't be dealing with RC4WD regarding Eagle's products. Guess I was right, they are trying to pass off the first version as the current one! That's hella shady! Going to continue buying directly from Eagle.
Old 05-21-2016, 08:02 AM
Yea, I usually give a strike or 2 to vendors before getting on them but this is really getting out of hand. If it comes to it do u mind if I send them the pic of yours Farmer?
Old 05-21-2016, 09:38 AM
schmoking schmoking is offline
schmoking is on a distinguished road
so... first they tell you it has a new 3 valve block system and they are no longer shipping the 1.5 with a 4 valve block, then they ask you where you heard about 1.5's being shipped with the 4 valve block???
i thought rc4wd was a decent company... did they change owners or something? i been saving up to buy the wheel loader from them, sure not gonna happen now!!!
Old 05-21-2016, 01:36 PM
alaskantoy alaskantoy is offline
alaskantoy is on a distinguished road
Just wanted to tell you that you're not alone. Dealing with this exact issue as we speak. Mine was shipped about a month ago and now im trying to get it up and running and ran into the three valve vs four valve block issues. Im waiting to hear back but my immediate reply to their 2 day reply definitely slows this down. Good luck........ as it seems we both need it and many more may as well
Old 05-21-2016, 02:05 PM
Glad to hear I'm not alone on this but also discouraged it's happening at a frequency now. Let us know how you fare and I'll keep updating as well. Does yours have spring loaded idlers?
Old 05-21-2016, 02:06 PM
Sure Benny it ain't a problem use the picture, anything to help a member out. Have you contacted Tang about the issues your experiencing with one of their dealers ?
Eaglemach@foxmail.com
Old 05-23-2016, 01:54 AM
I just received an email stating I received the "updated" valve hydro block. still having issues with slow movement, and the hydro lines loosening up and causing leaks and sucking in air.
Old 05-23-2016, 04:40 AM
Rimrock Rimrock is offline
Slow movement is likely due to air in the system. Too low oil level in the tank. I don't have a quick, good 'non messy' way of emptying the system for air, but maybe others have? Theoretically the air should come out by running all cylinders in and out enough times, having the tank filled up to proper level at first.
Adding thread locker to the nipples will not hurt. E.g Locktite 542
Old 05-23-2016, 05:18 AM
Sad to hear about the troubles someone experiences with the equipment. I guess one can state that RC4WD is more of a pure 'forwarder' of deals/money between the customer and the fabricator, Eagle. Not a real 'dealer' like one have with full scale machinery, that test runs, upgrades things before delivery, give full service, keep spare parts locally and so on. It's all very cost driven, companies like RC4Wd want's to have minimum stock and personnel, to keep costs down. That naturally influence the degree of service and quality of the delivery. I don't know if there are, or there should be, a professional dealer of the machines in e.g the US, that have good technical knowledge, keep spare parts in stock locally, and really test, check and possible upgrade the machines before delivery. the hobby is quite new..but hopefully things will improve over time and one will have more options than relate to unprofessional 'forwarders' or relate directly to a factory in China, that also keeps number of staff down in order to keep low cost.
If not getting original hydraulics properly up and go, there is always the option to put proper hydraulics in, Premacon, 1000-1200-1400 usd (If so, ask/look for advice at the forum concerning all parts needed in such a upgrade first, if one are not very into hydraulics)
