Old 05-20-2016, 02:28 PM
Cat966c Cat966c is offline
Cat966c is on a distinguished road
Default Re: good dozer gear motor
Originally Posted by SteinHDan View Post
I've used this type for various projects, and it worked very well for me with 3S battery. I've seen some others on here use it too. Totally quiet and very strong. Rated torque at ~30kg/cm and stall torque at up to 87.5kg/cm for the ~15 RPM versions. Lots of RPM versions available.
There are at least two alternative vendors for this form factor:
- GW31ZY-14 12VDC 14RPM 30kg/cm
- TSINY TS-40GZ495-1216 12VDC 16RPM
Specs for the TSINY version:
- http://www.tsinymotor.com/Products/W...4/0513/16.html
Best regards,
Stein :-)
So let me see if I understand this right (I guess this is a test of what I've learned so far lol): if those motors are 12 volts, then an 11 milh battery wouldn't have enough power to feed them? Is that right?
