View Poll Results: Would you buy this if it went into production?
Yes I would buy a metal version 13 34.21%
Yes, but I would like a cheaper plastic version 18 47.37%
No, there are better options out there 7 18.42%
Voters: 38. You may not vote on this poll
Old 06-02-2016, 12:01 PM
Doggy's Avatar
Doggy Doggy is offline
Doggy is on a distinguished road
Default Re: Tamiya bolt on reduction gear
Thank you for replys. I would like to answer to you that this case design is only for 3D print version. Milling and 3D printing have 2 completly different aproach. So this is designed so I can get the best print result, and all these 3D sufraces are there for a reason, to be strong enough as the hold ballbearings and load of the shafts. So its more of the ratio for added material where its needed, and again not to much so I dont wait too long for it to print out. So its function over fashion
Milling version will have only streight cut gears, and much simpler case. But the gear ratio will stay the same.
I added a poll, maybe it could give us some results to point this the right way.
Old 06-02-2016, 02:10 PM
Your idea looks very well thought out and looks promising. Are you aware PMD already has an add-on reduction box for the Tamiya trans? Installation, overall design and appearance is similar to yours.
Tags
3speed, gearing, reduction, tamiya
