View Poll Results: Would you buy this if it went into production?
Yes I would buy a metal version 13 34.21%
Yes, but I would like a cheaper plastic version 18 47.37%
No, there are better options out there 7 18.42%
Voters: 38. You may not vote on this poll
Old 06-02-2016, 11:24 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
Default Re: Tamiya bolt on reduction gear
Plastic might be a good alternative to the PMD one already out there. You mentioned 8x8 and for that you'd need front output also (and reduced) or a separate transfer case anyways. I haven't seen it by a US seller, but a longer output shaft can be made for the 3 speed. I think Willy (CustomRCModels) made them for himself? I think you'd be better off with an R2 IMHO. Freddy used axial transmissions as transfer cases and they were sweet at the time before there were so many options available to the hobby.
Tags
3speed, gearing, reduction, tamiya
