Old 06-16-2016, 06:45 PM
Default Re: RC4WD Semi Diff
http://store.rc4wd.com/Scale-Semi-Tr...al_p_2891.html
Is it an exact matched ratio to the stock semi axles?
I seem to have a lot of trouble with just the middle diff with either stripping teeth off the front pinions or breaking spider crosses within the differential. I see it says hardened steel internals, does that include the pinions too? Anybody torture these axles yet?
I believe they are made by the same vendor that makes the axles for the Eagle pay loader so I would not count on the Quality being that good.
If you don’t mind the axle being locked use the hardened pinion and spool from RC3WD
http://store.rc4wd.com/STEEL-BEVEL-O...D40_p_348.html
