Added the final angle sensor that reads the angle of the boom. This sensor is the same as the previous two, except that it's mounted a bit differently and it has no cover.
With this sensor in place it's finally possible to run the excavator without risking to break it. :-) If I have time later I'll try to read the rest of the positions and angles with encoders for the swing and tracks, and an IMU (BNO055) + GPS for the house. ![]() ![]() ![]() |
Running lines along the arm.
I need to run the power to the bucket motor and wires for the bucket and stick angle sensors along the arm. Also, I want to attach some auxiliary lines that can be used for various attachments later. I ran totally overboard with the auxiliary lines. I've added: - 2 x 2 x 0.75mm2 power line with XT-60 connector (one on each side) - 2 x USB cable (one on each side) The power lines can run about 10A each and can be used for driving motors, lights, etc. The USB cables can be used both as USB cables and also as just normal wire that can be used for driving servos or sending back sensor data. Each USB cable has two wires that can run 2A and two signal wires that can't really run any current, but can be used for signals, like the servo position (the white wire) or sensor output. So the USB cable doubles as a servo cable that can control two servos, just normal power lines (2A) or sensor wires. With a small adapter from USB to Futaba connectors, it will be easy to hook up servos. Some examples of what can be attached: - Quick coupler (using just one power line and that stops on a set current limit) - Impact hammer (one power line) - Drill - Saw (garden timmer, angle grinder, etc) - Light - Any USB device, like a web camera, a 3D depth camera like the Kinect, a desktop rocket launcher, a 32 channel servo driver, etc, etc. USB cables have very varying current capabilities. The cable I'm using here has very thick power lines and the thickness and stiffness also helps to give a visual appearance more similar to hydraulic lines. The the three-wire sensor cable, two-wire power cable and the USB cable: ![]() I've 3D-printed three different types of clamps to hold down the wires along the arm. The screws are 2.6mm x 8mm self-tapping screws. ![]() And a terminal at the stick: ![]() ![]() And it all attaches to the arm in this way: ![]() ![]() ![]() ![]() ![]() ![]() |
It's always a question where to put the required RC-components on a machine. I'm talking about things like the on/off switch, charge connector, etc. I want them accessible, but not visible.
On this machine, they could all go underneath, but I'm thinking that there might be a lot of dust, dirt, braches, leaves, etc there, and also it's not that accessible on the underside. So on this model, I opted to put them on top, but conceal them under a lid. I'm mimicking the engine lid from the original: ![]() And then underneath the lid, the control panel is located. It has: - The on/off switch - A battery voltage meter - A sound volume dial The charge connectors are just a standard XT60 and a balancing connector that are accessible under the lid, not attached to the control panel. ![]() ![]() The control panel stand also serves as the mount for the audio amplifier. The amplifier is a 2x50w D-class amplifier. The volume control is a stereo logarithmic pot - A1k. Ebay links: - Amplifier: http://www.ebay.com/itm/272163830096 - Volume control: http://www.ebay.com/itm/331883285534 - Voume cap: http://www.ebay.com/itm/221309764371 - Voltage meter: http://www.ebay.com/itm/201546863361 ![]() ![]() ![]() ![]() ![]() |
