Old 07-01-2016, 06:44 AM
Doggy's Avatar
Doggy Doggy is offline
Doggy is on a distinguished road
Default Re: upgraded front shocks
Why nobody use real shocks with oil, and let the springs take the load you want? I am just looking into materials to use for leaf springs to have flex and adjust the thickness of the leaf to decide how much load you want to carry. Easier way is if you use airbag dummy springs.
I will make some examples when I come to that on my custom truck build, as I want to replicat exact 1:1 system.
Old 07-01-2016, 08:38 AM
TRUCKMAKER's Avatar
If your using stock Tamiya suspension you can go to Tamiya USA and order spring leaves to add to your springs they have 4 different lengths. It works a lot better than trying carry the weight on shocks. Use the following link and look at the first 5 items on the parts list.
http://www.tamiyausa.com/product/rcp...2#.V3Zf4pD3aK0
This is the best picture I have albeit a rear set I did the same with the front. If you are hauling the weight this will take care of the squat and will still allow the suspension to flex. I believe I added 4 leaves per spring assembly.
