Old 07-05-2016, 06:06 PM
ricm ricm is offline
Default Re: Going Green
Originally Posted by Doggy View Post
I dont see a way to brake a plastic axle hehe.
I ment photos of inside of the axles, I am interested how they setup the locker on it.
Ah - I did pull the axles apart when I got them, to see how the worked....but didn't take any pics...not wanting to pull apart now, sorry! there is a dog clutch on one half shaft which slides across to lock the shaft to the crown wheel. It does have a spring return inside the axle, but it's not strong enough to pull the cable back when the cable tension is released - the diff lock stayed 'on' even when the servo turned back to 'off'. So I had to design the servo horn so it also pushes the cable back to 'unlock' when the servo turns back.
Old 07-08-2016, 10:22 PM
Supermario's Avatar
Truck is coming along great! I like your steering mod
I just found this steer link not long ago which also gives max turning angle. A friend of mine has been making out of threaded rod but these are solid and look great.
http://www.rigidrc.com/shop/rod-ends...eye-121mm.html
Old 07-12-2016, 04:36 AM
didn't know this bent track rod existed - probably do the job just as well as my mod, but doesn't need a lathe with vertical mill slide to get there
