View Poll Results: Would you buy this if it went into production?
Yes I would buy a metal version 13 34.21%
Yes, but I would like a cheaper plastic version 18 47.37%
No, there are better options out there 7 18.42%
Voters: 38. You may not vote on this poll
Old 07-16-2016, 04:31 PM
bigford's Avatar
bigford bigford is offline
Default Re: Tamiya bolt on reduction gear
Drilled a hole for the shift rod.. smooth gru now to see the pulling power
Way to go ivan!!!
Tags
3speed, gearing, reduction, tamiya
