Get some #5-40 taps Jim. They are smaller but the finer thread make it easier to tap.
Made some progress this weekend. Here is the new prototype drive tumbler just about ready to go back together for a test. I will make a new wider one with wider side flanges, once I see how it works. I moved the side rail out another 1/4" and made new lower idlers.
![]() Jim |
I am reworking the frame rails for my crawler, but, it has a twist in it. Here is a short video that should explain what I mean.
http://youtu.be/0Eqewf_Ekmc Part of the reason I wanted to rebuild these parts was the same twist in the old parts. ![]() I tried to carefully drill the two sides while clamped together in the mill vise. I tried to carefully turn the spacers in the lathe. The order was... Chuck the stock in the 3 jaw, center drill, drill center clearance hole to size. Turn outside diameter down just enough T to make it round and concentric to the center hole. Part off. I faced one of them to match the length of the first. I DIDNT machine the inside mating surfaces of the bar stock. If I loosen the clamping screws a bit and tweak it as I tighten it is better but I want to try and figure out what I might be doing wrong. Jim |
