Old 07-18-2016, 08:30 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Re: Ny-Lint Mobile Dragline Conversion
Made some progress this weekend. Here is the new prototype drive tumbler just about ready to go back together for a test. I will make a new wider one with wider side flanges, once I see how it works. I moved the side rail out another 1/4" and made new lower idlers.
Jim
Old 07-18-2016, 10:59 PM
Rvjimd's Avatar
I am reworking the frame rails for my crawler, but, it has a twist in it. Here is a short video that should explain what I mean.
http://youtu.be/0Eqewf_Ekmc
Part of the reason I wanted to rebuild these parts was the same twist in the old parts.
I tried to carefully drill the two sides while clamped together in the mill vise.
I tried to carefully turn the spacers in the lathe. The order was...
Chuck the stock in the 3 jaw, center drill, drill center clearance hole to size.
Turn outside diameter down just enough T to make it round and concentric to the center hole.
Part off. I faced one of them to match the length of the first.
I DIDNT machine the inside mating surfaces of the bar stock.
If I loosen the clamping screws a bit and tweak it as I tighten it is better but I want to try and figure
out what I might be doing wrong.
Jim
