Old 07-21-2016, 07:00 PM
modelman modelman is offline
Default Re: Ny-Lint Mobile Dragline Conversion
Jim-sometimes these jobs take way more time than expected, but as long as the results are what you want is all that matters. I don't see a problem with the tensioners. Once you get them set, I doubt if you will need to adjust them unless you plan to crawl this model many many hours. The new track system looks and works great!!! You might consider putting a jam nut on the tensioner bolt in case it wants to move. Just a thought.
