Thank you Emil, Jack and Dan! Yeah, trying to keep it scale. 3D printing takes you a long way, but you still see the layers. Suppose some careful grinding could take care of that.
Now, machining of the lift cylinder arms has been almost completed. Just need to fill out some shrink holes (and grind out the layered structure ![]() Drilled and reamed to 14 mm. Bushing with a 12° conical hole for an indexing lock pin. The indexing lock pin mechanism (still to be made) will be attached on the rear side of the plate with the "key hole". Cheers! Stefan Last edited by Stefan; 11-11-2017 at 09:46 AM. Reason: Link repair |
Amazing!
Tags |
1:8, grader, volvo |
