the springs for the hilift are longer than the semi set, you might want to modify the ones you have.
I curled up the 'b' helper springs, and got the front end looking a little better. Once i got the front of the springs mounted, and played with shackle lengths on both ends.
![]() And mangled a hole in the chassis, got the trans mounted up to some brackets. ![]() ![]() And i still have some suspension travel when it's got a load of dirt on. ![]() Cab mounts i went really easy / lazy: I stuck a bolt through the bumper rivet holes and cab, threw a nut on those, the bolts slide into the original chassis rivet holes, then the stock tabs slide into the original slots. Last edited by frizzen; 08-08-2017 at 12:56 AM. |
Bottom view
![]() Got the interior back in. Trans clearance wasn't as brutal as i expected it to end up. ![]() I know by the stunned silence you've all been wondering who would run such a modern, immaculate, classy, and well preserved vehicle in their fleet? ![]() I haven't come up with a great company name yet... We better hope i get creative before my dragline crane becomes part of that guys other division Mike Oxbig Erection and Mining. ![]() Last edited by frizzen; 08-08-2017 at 01:03 AM. Reason: Fix da pics |
Much fun at the Indy 2016 show on friday!!!
![]() ![]() shook a spring loose, hit the shop ![]() hit the general store for lunch ![]() ![]() Last edited by frizzen; 08-08-2017 at 01:16 AM. Reason: photobutt |
Here was the truck before i started modding, i had yanked one of the tandem axles off since it only had enough retainer clips for one rear. I was hoping for a stance more like this than my big lifted truck.
![]() Last edited by frizzen; 08-08-2017 at 01:19 AM. Reason: photobutt |
So lessons from indy:
Rock crawlers aren't fast. Taking the 3.770 tall tires off and replacing them with 2.315 tall tires means that you need to pull over and let everyone pass. Seriously, everyone passed me. I can reach top speed in under a yard. I have more torque than the tires could ever use. Must regear the trans! Drilling brass bushings from round stock by hand makes a really wobbly setup. I need to either redo wheel pin drive using tubes, or grind the tires to the new round, or get different rim/tire combo. I also learned its possible to have a car shake the rear suspension apart, um, in like 1 battery pack. ![]() Setting the suspension up for heaping load of dirt doesn't work that well for crumb rubber. Full load of rubber, no movement.. this didn't help the out of round tire situation since there's no real spring or any dampening. Once i got home I loaded the bed with soda cans, and learned the rear springs didn't get near max out until 6 pounds, i need to pull a leaf.. My transfer case still needs lowered since my drivelines are horrible, i need to shorten the rear springs. i need to put deans plugs on so i can use better battery and charger. I need some lights, a trailer hitch, and mudflaps. i've also got a few ideas for some interior detailing... Kinda getting tired of talking to myself though. Last edited by frizzen; 08-24-2016 at 05:25 AM. |
If anyone may be interested in these donors, here's a bit more i've learned.
Turns out I used a 1965-66 only configuration Structo hydraulic dump truck. I still have no clue if it's supposed to be based on any kind of real truck, or just a generic truck. Stock steering on the Redcat Everest / Exceede Maxstone donor is kinda bad and understeers a lot, here's the biggest part of the fix: http://www.rccrawler.com/forum/newbi...tuning-10.html Redrill knuckles for zero ackerman, make new draglink and tierod. Eliminates tire scrub, it's still turning a 4 locked truck, but atleast you can steer the same direction. On the trans, up to 370 brushed motors fit, and stock esc will support them. The differentials have a 14t pinion, 38t ring. Which is 2.714 to 1. The motor pinion is 14t. i don't yet know the spur size, or the trans total ratio. Any specs or dimentions that might be helpful? |
