Old 07-31-2016, 04:58 PM
Jack3M Jack3M is offline
Default Re: 4200 XL shear pin repair
Of note, I made a new shear pin out of a piece of mild steel I had. Not sure how hard it should be, not hard to fix this really. If just the shear, you don't even need to remove the motor actually.
But to line it up was difficult, and I learned that by loosening the 4 set screws for holding the motor and pulling the motor out toward the cap a bit, made it much easier to get the new pin lined up and in place. Put the keeper set screws back in. Then push down hard toward the O-Ring so that it seals the whole unit from the environment.
So, my benefit from all this is I saved a bunch of cash after having just gotten this. Also, that unit is not a bad piece of work, all the gears are metal. I just increased the amount of grease on stuff. Albeit slow, these units are pretty sneaky smart.
