View Poll Results: Would you buy this if it went into production?
Yes I would buy a metal version 13 34.21%
Yes, but I would like a cheaper plastic version 18 47.37%
No, there are better options out there 7 18.42%
Voters: 38. You may not vote on this poll
Old 08-04-2016, 01:35 AM
Default Re: Tamiya bolt on reduction gear
Just a couple of thoughts: The Tamiya gearbox is pretty much bullit proof if out together correctly. It has a bit of internal slack, but is very durable.
As for the steering, hydraulic steering would be a cool feature, but I think you will be more than happy with moving the servo between the frame rails. I normally use Hitec645MG servos for steering, and they are strong enough.
Tags
3speed, gearing, reduction, tamiya
