Old 08-20-2016, 03:37 PM
Default Re: Electrical question
It varies a lot how much power an ESC can deliver to the RX. I would look up the spec on your ESC to see if it can power the RX plus three servos (for your valves). If you have the model number or product name, I can help you look it up.
If the ESC does not deliver enough power, then you can buy a separate SBEC/UBEC:
- Hobbywing 5V/6V 3A Switch-mode UBEC
- Turnigy 5A (8-26v) SBEC
- Hobbyking YEP 20A HV (2~12S) SBEC
Also you should not use both ESCs (or any two sources) to power the RX at the same time, as this could damage the ESC depending on how its BEC circuitry is build. Just use one ESC and remove the power line from the other, like this guy does:
- https://www.youtube.com/watch?v=clNvfjhMQ5w
If you end up using an external BEC, then remove the power lines from both ESCs.
Best regards,
Stein :-)
Old 08-20-2016, 09:06 PM
crusher's Avatar
crusher crusher is offline
crusher is on a distinguished road
Thanks Stein, the ones I have are "Proboat" they list BEC output as 6vdc,1 amp max. forward current 50amps reverse 20amps, not expensive.
Terry
Old 08-21-2016, 03:29 AM
1A is pushing it a bit, in my opinion. I usually assume 250mA per servo for no load and 1A per servo at stall. I guess in your application the chance of stalling the servo is very small as turning the valve probably isn't very heavy on the servo? But anyways, 3x250mA for the servos +50mA for the RX is around 800mA total which is quite close to the max 1000mA of your ESC.
You could get a 3A (or 5A) SBEC/UBEC to be on the safe side, and also it would be good to have that extra power if you're adding other things later, like lights, rotating beacon, rototilt, quick coupler, etc.
Best regards,
Stein :-)
Old 08-21-2016, 03:08 PM
crusher's Avatar
Thanks for your help Stein, I think I am going to buy a separate bec and disable the red wires on the esc. That way I will be covered.
Terry
Old 08-24-2016, 03:13 PM
Best regards,
Stein :-)
Just wanted to say this post made my day. Just installed a sabertooth dual 25A ESC and was having a motor twitch problem in one track motor. I had left the positive from the pump and slew motor ESC's into the RX. Once I removed them and had just the sabertooth powering the RX all was fine. Gotta love forums such as this!
