Old 08-20-2016, 09:06 PM
crusher's Avatar
crusher crusher is offline
crusher is on a distinguished road
Default Re: Electrical question
Thanks Stein, the ones I have are "Proboat" they list BEC output as 6vdc,1 amp max. forward current 50amps reverse 20amps, not expensive.
Terry
Old 08-21-2016, 03:29 AM
1A is pushing it a bit, in my opinion. I usually assume 250mA per servo for no load and 1A per servo at stall. I guess in your application the chance of stalling the servo is very small as turning the valve probably isn't very heavy on the servo? But anyways, 3x250mA for the servos +50mA for the RX is around 800mA total which is quite close to the max 1000mA of your ESC.
You could get a 3A (or 5A) SBEC/UBEC to be on the safe side, and also it would be good to have that extra power if you're adding other things later, like lights, rotating beacon, rototilt, quick coupler, etc.
Best regards,
Stein :-)
Old 08-21-2016, 03:08 PM
crusher's Avatar
Thanks for your help Stein, I think I am going to buy a separate bec and disable the red wires on the esc. That way I will be covered.
Terry
