Old 08-23-2016, 06:01 PM
Efroeh Efroeh is offline
Default Re: Tonka bottom dump conversion
Got some pictures today it was raining out so no in use videos. For the conversion I try to buy a used axial scx 10 scale truck. Basically tear it down use all electronics full axle assembles. Uses some aluminum to attach it to the frame. You have to cut some of the tonka frame down so the axle will sit were the tonka axle did. To move the bottom dump open and close used a firgelli actuator attached underneath to the closest one and a peace of aluminum attached the two openings. If any more question just ask. ( it makes sense in my mind but that doesn't mean it does for everybody else haha) on to pictures
The rear axle had to be narrowed so it would look proper.
All the electronics are under the cab for a nice clean look
Old 09-10-2019, 01:34 PM
flexintex's Avatar
flexintex flexintex is offline
flexintex is on a distinguished road
hey, i found this thread but the pictures are gone. is it possible to post them again somehow? I am doing Tonka RC Conversion. I want to see how you did the actuator. I was thinking vertical lift, but sounds like you may have done a hinged lift underneath. if I could see the pictures it would really help me out. Thanks!
In Dallas, TX, USA. Own a Liebherr 954 hydraulic excavator, RC4WD 870k Loader, Converted Tonka dump truck. Have a couple Grand Haulers as well. Created Facebook group: DFW/North Texas RC Truck And Construction.
