Old 08-23-2016, 11:02 PM
jack van's Avatar
jack van jack van is offline
Default Re: How to self center throttle stick on dx18 radio?
i would also like to know that as well
Old 08-23-2016, 11:49 PM
Krewmember's Avatar
I did a quick google search and found this video https://www.youtube.com/watch?v=Wy9PvqpWUnc
It may help you if the DX18's gimbal assemblies are the same as the the DX6i's
Shawn
Old 08-24-2016, 07:42 AM
Jack3M Jack3M is offline
Interesting, I would assume the same can be done on the 18, I could look into mine later, but I still use it for flying also. Nice to know though
Old 08-24-2016, 03:41 PM
Shawn
It's similar to that, but I can't recall if I had to split the case or just access a set screw from under the left glued down grip to release the ratchet. There's 4 small rubber plugs you see on back of radio, there for adjusting spring tension on each up/down - left/right travel of each gimbal.
The DX8 is super simple with just one small rubber plug on each side to release/engage the ratchet.
