View Poll Results: Would you buy this if it went into production?
Yes I would buy a metal version 13 34.21%
Yes, but I would like a cheaper plastic version 18 47.37%
No, there are better options out there 7 18.42%
Voters: 38. You may not vote on this poll
Old 08-26-2016, 01:52 PM
JBear JBear is offline
JBear is on a distinguished road
Default Re: Tamiya bolt on reduction gear
Hello
Look's good. I like it especially with disconnectable front bridge and option to leave battery on it's original place.
Shouldn't the gru be right under the top of the chassis line? The trailer will hit gru if you move the kingpin to correct position (about 10 mm backward from the middle axle, like for example Scania r620 has in real world).
Regards
Jukka
Tags
3speed, gearing, reduction, tamiya
