Once I figured out how to do the hex I decided to go big. So, I'm making hubs for the wheel with the hex and a flange that looks like a brake rotor. That pulls up against the inside spokes of the wheel with a 6-32 cap screw to keep it parallel with the wheel. Then I drill the inside of the hub to fit a 1/4" steel axel.
Hex milled on the mill using a slip fit nut attached to the round. Then moved to the lathe to turn the rest. ![]() Turned down and parting it off here. ![]() ![]() ![]() Jim |
Independant suspension, coilovers, alloy super-singles, brake disks... somebodys building a Sports Dump Truck!
Looking really cool so far. I can't wait to see how it turns out. |
![]() ![]() ![]() ![]() Jim |
Here is my version 2 prototype rear axel. Thinking about how to do the halves from the gear cover out to each wheel. I want to do a "typical" style solid axel with leaf springs.
![]() ![]() Jim |
