That's pretty much exactly what i had been thinking, i just didn't know how much force the machine uses vs the plastic strenght. I was trying to overcomplicate things.
I'm going to have to send you a pm, that's looking beautiful. |
As long as you add a support rack for the off side I think it will work great, I only put two screws in the plastic horn. The screws are about 1/2" of from center so they will have all kinds of torque way out there and they only need to turn the drum. I have two of them made.
Jim |
Here is the third one in the lathe, just about to drill the center hole.
![]() Frizz, send me that PM. I can probably send these to you Thursday. I'm think I'll make the mounting bracket for the servos and the off side support as well. Jim |
Frizz,
Here are the three drums. I made a little angle bracket for them and decided to stop there and see what you think? They will need a strap across the opposite end of the servo mount tabs and I used a small 1/4" channel for the off end drum support. The center hole in the off end of the drums could be enlarged a bit at the end to match the head of a #6 cap screw which could be threaded into the channel to support the off side of the drums. ![]() Jim |
At this rate, you'll need to write up a dimensioned spec sheet on the parts or start offering kits.
Those are looking really great! |
As far as i've found, real Clark Michigan cranes seem to be set up with a pair of dead lines off the tip to a sheeve block, cables run from the sheeves back to the house some unknown number of times for mechanical advantage and to reduce the amount of cable.
![]() ![]() these are the most helpful images I've been able to find so far Stock toy just had it route: fixed at house, tip pulley, cable drum. And it works fine as a toy. Atleast for now, i'm thinking split the difference like jim did: fixed at house, tip, house, tip, house, drum. Last edited by frizzen; 07-19-2017 at 04:03 AM. Reason: photobutt |
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
