Old 09-01-2016, 11:44 PM
Jared Jared is offline
Default Re: Bucyrus Erie crane truck
Originally Posted by Krewmember View Post
I'm still trying to figure it out how to go about making the cranes frame. my plan was to mill a base out of a block of aluminum, but I no longer have access to a milling machine. So that plan is out maybe I can solder together a frame out of brass
Shawn
Coming along nicely. I'm digging the B-E house. Maybe this will give you a little inspiration for soldering it from brass which is what I did before I had a mill. No build pictures but hopefully you can see what's what. http://www.rctruckandconstruction.co...read.php?t=992
Old 09-02-2016, 11:31 PM
Krewmember's Avatar
Thank you, that's pretty much what I had in mind.
I just looked in to what it would cost to make the base out of brass, and it would be a little out of my price range
But I have access to a welder, so I can probably use steel instead.
Shawn
