![]() Thank you. And yes my original plan was to mill down a block of aluminium, but I no longer have access to a milling machine. I would however be able to use aluminium flat bar and plate. BUT I would have use epoxy as I do not have access to a tig welder. Edit: or maybe brazing ![]() Shawn Last edited by Krewmember; 09-03-2016 at 11:21 AM. |
This project has been the back burner sense my last post. Again
![]() But a couple of days ago I finally pulled it off the shelf and did some detail work mostly on the crane carrier but. I did add sliding doors and rivets to the back of the crane as well. ![]() ![]() As for the carrier, I added a battery box and the fuel tank. And some trim to the cab as well as a opening door. ![]() ![]() ![]() ![]() ![]() ![]() ![]() I'm still having trouble deciding the best way to approach the mechanical parts of this project, and to make things harder my little craftsman lathe is still not running do to a missing drive pulley which for the life of me I cannot find for sale anywhere ![]() Shawn |
