If anyone may be interested in these donors, here's a bit more i've learned.
Turns out I used a 1965-66 only configuration Structo hydraulic dump truck. I still have no clue if it's supposed to be based on any kind of real truck, or just a generic truck. Stock steering on the Redcat Everest / Exceede Maxstone donor is kinda bad and understeers a lot, here's the biggest part of the fix: http://www.rccrawler.com/forum/newbi...tuning-10.html Redrill knuckles for zero ackerman, make new draglink and tierod. Eliminates tire scrub, it's still turning a 4 locked truck, but atleast you can steer the same direction. On the trans, up to 370 brushed motors fit, and stock esc will support them. The differentials have a 14t pinion, 38t ring. Which is 2.714 to 1. The motor pinion is 14t. i don't yet know the spur size, or the trans total ratio. Any specs or dimentions that might be helpful? |
So what's the most important part for a DUMP truck to have?
Yeah, you'd really think so... ![]() But instead of getting that part so it can DUMP: i made light mounts, hacked servo board so the lights can be activated from the tx, made a trailer hitch, started working on a trailer, and made the steering wheel i'd thrown in there look less like a round servo horn. Other than softening the rear suspension a little by pulling the smallest helper spring, i haven't done much of the planned mods. Thinking i may try adding Plastidip to the tires to see if it helps with the traction situation. I knocked more rust off the hubcaps, but didn't try for too shiny, this trucks not about that life. Last edited by frizzen; 08-08-2017 at 01:21 AM. Reason: photobutt |
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
