Old 09-19-2016, 04:53 PM
Supermario's Avatar
Default Re: My first semi build thread
The truck is looking great so far. Your doing a fine job.
Playing catch up here but, I have to agree with truck maker. I was real happy with the concealed rod for the fifth wheel but as time went on I realized it's a bit of a pain and wish I had a manual release for those times when you want to uncouple and not have to power up the truck. That idea was short lived and I never bothered because I discovered another PIA. All my trailers have SS Tronix wireless systems with motorized support legs. I didn't want the manual toggle switch to run the legs and never installed so even if I can release the trailer, if the legs are up, I can't run them down without powering the truck up.
It's a bit annoying but Not bad enough to revamp the set up.
Keep up the good work.
Old 09-19-2016, 05:09 PM
Just_Build_It Just_Build_It is offline
Just_Build_It is on a distinguished road
Thank you, Sir
It sounds like you have quite a debacle on your hands and changing, building and creating is the best part about this hobby. For the fifth wheel I'm going with the braided steel wire so I don't run into the problems previously mentioned.
How do you like that wireless system for your trailer? Eventually I would like to use a wireless trailer system when the time comes.
Old 09-20-2016, 05:35 PM
Supermario's Avatar
I've been happy with the system. Plug n play, very reliable , but expensive compared to other systems out there. Another issue is only having one aux channel for the trailer. What I mean is, if you have a dump trailer you need that channel to run the dump box which means you can't run motorized legs also.
That's how my dump trailer is set up with manual legs. Once trailer is hooked up and dumping, who cares about the legs anyway.
The other nice thing about SS tronix is capacity. can handle 120 LEDs on trailer and another 120 on the truck.
...before I forget, SS Tronix system is designed to work with a MFU. If your going to use any other ESC set up, this system isn't right for your build.
Old 09-20-2016, 06:15 PM
Good info to have since I do want to get and/or build a dump trailer. I haven't really decided on a particular mfu or esc yet. I'm also thinking about getting a 9 channel radio for this truck and future trucks. Right now I'm running a cheapo hobbywing esc with only forward/reverse before I spend money on something that is programmable like a Holmes or a Tekin. So I want everything wireless so I don't have to touch my truck while operating it.
