Old 09-28-2016, 12:03 AM
DADSGARAGE's Avatar
Default Re: PC1800 Front Shovel (1/12)
Originally Posted by JAMMER View Post
Great idea for the tank filter and nice work. You do come up with some great ideas. Ed
Thanks!! The tank filter/screen design was really just a fluke, was originally thinking of just soldering the screen to the outside of the copper tube but luckily found some brass tubing that fit really snug against the screen when inside the copper tubing, sometimes luck is just as good as skills!! LOL
Nice to see your able to carry on with the build! She's really looking like a mean machine coming together.
Tank features are very cool and love it. One thing that came to mind though, it's hard to tell in the pics but how thick is the tank walls? Just wondering about cooling factor..... Then again, such a large surface area heat retention shouldn't be a problem?
The tank wall is 3/16" thick, the reasons for it being that thick is to be able to cut pipe threads directly into the tank wall....the original design had some threaded holes on the side of the tank as well but ended up changing things around a bit and just decided to use the same thick wall square tubing....already had it so hey...got to use what you got!! Hopefully heat retention doesn't create any problems, I think it would take a long time to heat everything up enough to cause any troubles...hopefully! Lol
Old 09-28-2016, 12:50 AM
DADSGARAGE's Avatar
Originally Posted by sparkycuda View Post
Very glad that you did not suffer any big damage - and prayers for those that lost everything. Your hydraulic tank has more features than some I've seen on real machines and the shovel is looking really great.
Me too!!! We do know a number of people who lost everything!! We are very fortunate to still have a home etc!!!
The features in this little tank might be a bit overkill but hey...why not!!
Thanks Ken!!
Originally Posted by tracksntreadslou View Post
Making some awsome progress ..this machine is build to last and some great features with the tank as well ...to darn bad you are so far away ..Btw sure glad you made it though that devastating fire ..so many people lost everything ..im sure you knew many ..my heart goes out to them
Slowly making some progress on this build, hopefully one day it will get completed...lol...I here ya on the distance gap, at least there are a few people in this hobby near you, must be nice!!
The fire has impacted everyone up here, some more than others.....some people are rebuilding and some are not. I know a number of people who never lost anything in the fire but have still decided to leave town...only time will tell how much this affected us all.
Old 11-24-2016, 11:36 PM
DADSGARAGE's Avatar
Got started building the boom...finally...started by laying out the sides and cutting them in the band saw.
After drilling the pivot holes I bolted on a couple of heavy washers (turned on the lathe) that had the proper diameter/ radius and then used the belt sander to grind the radius on the ends of both plates, the thick washers act as a guide and or stop point while grinding the rads by hand.
Old 11-25-2016, 12:44 AM
DADSGARAGE's Avatar
Really trying to hide any welds, so most of this will be welded on the inside. Only the longer top section will end up being plug welded from the outside.....so I milled a small shoulder on the edges of all three outer plates, doing this also leaves a small lip on all the edges much like the real deal.
The small slots on the front of the bottom plate are to allow the front pivot/hyd. mount plates to be welded on the inside, as well as locate them... (hopefully this will all make more sense later....lol....just need to make a few more parts of the puzzle)
