#1821
It's a haul truck not a race truck. Your lifting the
Heaviest load out anybody here. Leave well enough alone |
#1822
What is the # on the Jung pump? What do you have the pressure set at?
#1823
I thought it dumped just fine . Maybe open your fitting ports like Reg said .
#1824
#1825
Sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeetttttttttttttt tt!
#1826
WOWWWWWWWWWWWWWWWWWW
#1827
Sweet "Knockers" The whole thing is sweet Lot of Lovin put in to this MegaMachine.
#1828
Awsome ....the fine detail makes these models stand out ...nice ..How is the tapping going so far ..I have been doing quite a bit of 0-80 latley and it seems almost easier then the 2-56 and 4-40 ..Broke 2 2-56 on this my scraper build and one 1-72 ..2 of them were because I dropped them ..lol
I have to found some pretty good deals on Ebay for taps but should start looking for some good drill bits..my local suppler is charging over $5 a piece for the smaller bits ..they are good bits tho .. Nice work buddy |
#1829
![]() ![]() ![]() If I would have planned ahead,,,,,,,, I wouldn't have to make simple tools like this!! Had to make an extension for drill bit and tap for holes along bed rails. Hand drilled ![]() ![]() Like this hitch, have to tear the back end out to get in mill for cutting/tapping. Then thinking about small things like supports for wire to lights ect,,,, but I've learned if I don't do it now I don't do it. Still have lights for excavator laying around that I keep saying I'll get to!,,,,,,
#1830
Kerst |
#1831
is it going to be yellow for cabin fever???
#1832
Hopefully be yellow within next few weeks.
#1833
The trucks looking real good RW!
#1834
Wow you got that together fast.
#1835
Got to McMaster.com for your drill bits. You can get cheap ones or get the better ones much cheaper than from anyone local.
LYNN |
#1836
Much better in quality too . I get mine in packs of 12 .
#1837
New gears arrived today, just in time for tear down for paint. Ihave 144:1 reduction and with these new gears I can change to 108:1 That might be a little closer to scale speed. Also can go to 81:1 (or 96:1) but I think that will drastically drop my torque and be too fast.
![]() ![]() Paint time, was going to go with new cat yellow but I have several cans of old cat yellow. Oh well it will match the fleet ![]() ![]() ![]() ![]() ![]()
#1838
OK when did they change they're yellow again
#1839
I think they only have the two, the new yellow is more dark than the old. Probably been 10-12 years or more for the new paint.
#1840
One looks more mustardy
Currently Active Users Viewing This Thread: 79 (0 members and 79 guests) | |
