Here is a suggestion to improve flow to your dump cyls, use 4mm fittings on the valve to a tee block, then 2,5mm fittings from tee to cyls. The 4mm fittings on valve need to be filed down to screw into place, just leave enough flat spot to snug with a wrench.
