Old 01-03-2011, 10:20 PM
kerst's Avatar
kerst kerst is offline
Default Re: Liebherr LTM1800 scale 1/24
Originally Posted by 9W Monighan View Post
I originally was going to make my own collector rings but found one that suited.
Looking at your picture; Is the brass soldered to the aluminum? I've never tried to do that before.
Oh, did you mean the frame?
I glued the Al and brass together, but for strength a 1/4' bolt connects the brass with the center ring, a similar setup like pre-stressed concrete.
I like to use AL, because it is light and easy to work with and i found very good glue. But i don't rely completely on the glue; I mostly add bolts.
i made the outrigger beams from steel, because I wanted a lot of strength there.
I plan to make the telescopic boom from AL too. it should work and it will flex a lot more than steel. And i would like to achieve that effect.
Kerst
