Excellent craftsmanship! I have always been partial to the hydraulic builds, but this electric build has opened my eyes to new possibilities!
Sorry if you reported earlier and I missed it, but waht 3d printer are you using? And what mill do you use to cut your aluminum parts? Thanks! -Ben |
Thanks Mark and Ben! :-)
This electric version even exceeded my expectations. I was planning on testing the electric motors and then converting to hydraulic if it didn't work out. And I didn't actually think it would work, because the arm is so long and the leverage it puts on the motor axle is enormous. But it did work quite well and it can dig normal dirt, which was the goal. it even dug that gravel you see on the video. That's pretty tough stuff to dig. I also got rid of that gear backlash I discussed with Joe previously. It was by most part caused by a machine key inside the gear motor that wore down and not by the gears themselves. To combat this I welded the gear motor's final gear to the axle. The weld looks so bad that I don't think I can show it here.. but it works and removed the backlash. I've only done it on the stick motor, though, and I'm planning to do it on all the motors. The gear motors are so strong (320kg/cm) that they will rip themselves apart if not limited in some way. That's why I added the current limiting and the position sensors. I've set the current limiting to match the scale force of the original full-size machine. For example, I've set the current limiting for the boom so that it can lift 12kgs. Multiplied by the scale (1/14)^3 (three dimensions), we get 12kgs * 2744 = 32928 kg which is around 33 metric tons. That value is close to what the real machine lifts with the same arm configuration and arm position. So, the machine doesn't need to be any stronger to be a scale replica of the real CAT 390. I still don't feel too well about the leverage the arm has on the motor axle, though, so I've been thinking of maybe adding an external final gear that bolts directly to the arm and not feed the force from a 1m long arm through a 10mm axle. That also would remove the need to weld inside the gear motor. I guess the things I like best about it being electric is that it's very quiet and there's no oil anywhere. Stein :-) |
The 3D printer I have is this one:
- Makerbot Replicator 2X I like it a lot, and I even have two of them.. But it's quite an old 3D printer. I think these days, you can get better offers. The only important thing is that you can print ABS, because it's so much tougher than PLA (less brittle). And you need a heated build plate for ABS printing. Maybe one of these could do the job: - Ultimaker 2 - Zortrax M200 Pro - FlashForge Creator Pro I've not tried any of them, but I've heard some good things about them and the specs look ok. There's probably lots of reviews on youtube. My mill is a K2CNC KT-2415S with a Bosch 1617EVS 1400W spindle. The one I have is no longer sold, but I think there are some good quite cheap alternatives, like this one: - CNC 6040Z 3-axis, 1500W VFD spindle, 110V/220V ![]() I've not tried it, but the spec looks ok. 1500w spindle is good for milling aluminum. Ball screws are good. There are lots of reviews on YouTube. I saw these two: - Review: https://youtu.be/DeRuMZKCiy8 - Cutting aluminum: https://youtu.be/kTIYiZFGcRE Best regards, Stein :-) |
Now I'll get on to get the build finished! I'm working on the cab, windows, lights and webcam inside the cab at the moment.
Stein :-) |
Hi Stein
Happy New Year Any update of your build to share with us yet as I cannot wait ![]() Thanks for sharing with us all.
Regards Mark Over the Pond in the UK Member of Ribble Valley Radio Controlled Truck Club my weather station To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Hi Hofabooz!
Progress is very slow these days. Too much to do at work. But, I have an updated CAD file here, in case anyone is interested: - http://d1t2tbzmskak12.cloudfront.net...age_4+v300.f3d A screenshot: ![]() Best regards, Stein :-) |
I downloaded your fusion 360 model and I have been marveling at it. As a fairly new fusion user I have no idea how you accomplished this but it sure is impressive to look at! I am working on a little bruder conversion at the moment but who knows I may print a few pieces of this for fun. Thanks for sharing!
