Old 11-24-2016, 11:36 PM
DADSGARAGE's Avatar
Default Re: PC1800 Front Shovel (1/12)
Got started building the boom...finally...started by laying out the sides and cutting them in the band saw.
After drilling the pivot holes I bolted on a couple of heavy washers (turned on the lathe) that had the proper diameter/ radius and then used the belt sander to grind the radius on the ends of both plates, the thick washers act as a guide and or stop point while grinding the rads by hand.
Old 11-25-2016, 12:44 AM
DADSGARAGE's Avatar
Really trying to hide any welds, so most of this will be welded on the inside. Only the longer top section will end up being plug welded from the outside.....so I milled a small shoulder on the edges of all three outer plates, doing this also leaves a small lip on all the edges much like the real deal.
The small slots on the front of the bottom plate are to allow the front pivot/hyd. mount plates to be welded on the inside, as well as locate them... (hopefully this will all make more sense later....lol....just need to make a few more parts of the puzzle)
