Old 01-04-2011, 11:22 AM
JAMMER JAMMER is offline
Default Re: Taking Inventory
Nathan Scale Art sells two size tanks and pump the one for the dump trailer. The tank is 115CM3 240 ml. This does there 4 stage. It does 12 bars and is 326.89 Euro. Ed
Old 01-06-2011, 01:15 AM
Nathan, don't know for sure it's capacity, but I'd guess it to be 50ml. Not enough for wdc's 3stage telescope by itself, however I'd think you could tie this reservior tank to the fuel tank on the other side as well. This minature pump/tank is moreso I think for double acting cyls.
Thanks Ed and Joe. After posting, I did think about using the remote hydraulic tank idea too. I think it would nice to have an actual valve block to control the flow too. I know end dumps use gravity to bring the box down (1:1 dumps anyway - Wedico runs their pump in reverse to suck the oil out), but for something like a side dump, a valve block would be perfect. I'm going to look into a little more. I may not have any room for a valve block, a pump and a tank. Unless that valve block is small enough to fit inside a 1.5" O.D. fuel tank too. Boy, that'd be a alot of extra plumbing (more hydraulic line). Tank to pump, pump to valve block, valve block to couplers, and back.
Old 01-06-2011, 08:08 PM
Heavy Metal Heavy Metal is offline
Heavy Metal is on a distinguished road
Grumpy - I might just contact you about the tire mold service. Going to keep looking for another week or two. The rear tires on the old Ertl at start of this thread are almost perfect dia and width but tread pattern not so great. BTW...any how-to threads on the topic?
Old 01-07-2011, 12:52 AM
grumpygrady grumpygrady is offline
grumpygrady is on a distinguished road
here are a couple sorry didn't have time to really check them out but they are ones that i had saved
http://www.oldweirdherald.com/scales.../silicones.htm
http://www.automotivehelper.com/topic677276.htm
http://www.magazinepublisher.com/mod...res/tires.html this one i think is a seller that does 1/25 scale tires
http://www.rcuniverse.com/forum/m_19...tm.htm#1910499
http://membres.multimania.fr/philmodelcar/DSC02901.JPG
will look for more later
Old 01-11-2011, 08:06 PM
Grumpy - Thanks for links on casting tires. I have a reason to be in the Reading, PA area next week so going to stop by OutBack Toys in Lititz and see if I can find a couple die cast tractors with the size and tread pattern I'm looking for. If they are not rubber...I will probably give you a shout.
