Old 12-12-2016, 03:44 AM
Default Re: 1/14 buckles for curtain side trailer
Somewhere i saw a guy bend up thin wire into the shape of a digital 8 with a dab of solder at the 2 overlaps. I think he showed several ways to configure straps. I'm still trying do find the thread after a few days.
Anyway, grab needlenose pliers about the width of the ribbon you're using, and some thin solid wire. 1 jaw width make a 90 degree bend, 1 jaw width 90 this is buckle center, 1 jaw width 90, 1 jaw width 90 this is buckle bottom, 2 jaw widths 90, 1 jaw width 90 this is buckle top, then 2 jaw widths or just trim flush. Square up, glue or solder as required.
Easy way of rigging hook 1 strap around center leg, touch of glue, clamp with pliers until cure. Take other strap through top, over middle, and through bottom of buckle.
I think there was also something about glue strap at bottom, then take strap through top, around middle, back through top.
Old 12-12-2016, 03:05 PM
fvasileios fvasileios is offline
fvasileios is on a distinguished road
Thanks a lot for your help guys...
Cossett,I've used translations but most of the times I'm using a smartphone to search in the web and change tabs is boring.when sit on a PC it's a great thing to use...
Frizzen,thanks a lot for your explanation.it makes sense.I'll give it a try but if I'll fail I might go for the ready ones.they look very scale...
http://www.fechtner-modellbau.de/900...13x3x4-8mm.-10
Bill...
Old 12-12-2016, 06:40 PM
trucker n's Avatar
that site I told u about has links for different languages I cant read german either that's why I go to the English flag at the top and click that and it brings it all up in the languages u select
Old 12-13-2016, 08:17 PM
Above the search bar on that web site is a row of flags. If you click the British flag the site will now be primarily in english.
Old 12-14-2016, 03:54 PM
Thanks a lot guys for the flag suggestion...
I've searched the site many times for a flag.probably because of the smartphone it takes me to mobile version of the website that doesn't support English.
I'll have a try from my desktop...
Bill...
Old 12-18-2016, 08:29 PM
Check out his 3d printed simulated ratchet straps.
http://www.rctruckandconstruction.co...ad.php?t=12058
What size and style buckles are you hoping for?
(I shouldn't have come here, you made me play with ribbon and paperclips... )
