Understand! Was wondering if the cab and fender/hood assy. were for sale somewhere and then I found them at Shapeways. Is this cab the one with the non opening doors?
Looking forward to this build, as I might have to change plans on my 6x6 tractor build from a Globe to a R model. Spent a lot of years/miles in R models. I hear that sanding these printed bodies down smooth for paint is a bear... I'm using the F350 powered steer axle with F350 springs with factory holes drilled in them, and it does lift the front end up some. But so are the 1:1 6x6 trucks. I've seen some guys redrill the rear suspension mount holes lower down to get the frame to ride level. OK for a straight truck, but a tractor will be too tall to hitch up to stock trailers anymore, just like the 1:1. You just put blocks under the landing gear legs.
WILDCAT T&C Jim B. Colorado Springs Last edited by roadranger; 01-07-2017 at 07:10 PM. |
Looking good!
https://www.shapeways.com/product/SJ...=user-wishlist https://www.shapeways.com/product/DQ...=user-wishlist |
Well this thread is kinda old, PB wont show my pics, so Im going to post pictures directly attached here.
I have not lost interest in this project and I am trying to build this a little differently than standard practice. Which is probably not the smart way, but I am tying this with my other hobby of casting and forming metal along with my 3d printer and design ability. So I am actually attempting to cast the majority of the dump bed from aluminum which is going well, although it is a pretty heavy dumper I think it will still work fine, I will modify my pattern to make thinner castings and maybe even make the walls shorter and use a piece of wood at the top like some full size truck do. I attached some pictures of the process, the bed is cast from aluminum with traditional sand casting methods using petrobond sand and 3d printed patterns that I finished with primer and sanded down, the casting duplicate the patterns finish almost exactly, as this petrobond sand is MUCH finer than standard water bonded sand. |
Some more pictures of the dump bed.. This file uploading sure does take a long time!
Well, Im sorry guys if this isnt working but Im not seeing the photos.. Im hoping maybe they're pending approval by a moderator or something but here are more pics of the bed sitting on the truck.
