Old 01-07-2017, 08:55 PM
Bo Wallen's Avatar
Thumbs up Re: New RC trucker from the UK
Hi and Welcome to the Best RC Truck site on the net. The amount of helpful people and knowledge is astounding .
So let's start wit the steering mods. Take a look around, Most everything is here.
You can look at this tutorial and see what you could do. Good Luck and keep on Truckin'
http://www.rctruckandconstruction.co...ad.php?t=12133
Old 01-07-2017, 09:26 PM
SteveDownSouth SteveDownSouth is offline
SteveDownSouth is on a distinguished road
Default Re: New RC trucker from the UK
Thanks Bo.
I think I've sussed out my steering lock, it's just the play I need sorting out. I've been looking around the web tonight and have seen that I wasn't anywhere close to inventing the bent tie rod idea and moving the servos to the front. I thought I was being clever, but some more clever people came way before me!
There are two things I need to sort this out:
1 the ball joint ends need to be closed cap type to reduce play
2 the stub axles need to be shimmed or replaced with better fitting items
I don't know what the technical term is for the first, or the correct size, so searching for them is difficult. I'm not sure if anyone makes the second item, and if they do, who and how much they cost.
Any help appreciated.
Steve
Old 01-07-2017, 10:25 PM
Bo Wallen's Avatar
Originally Posted by SteveDownSouth View Post
Thanks Bo.
Steve
The answer on #1 No jus a better quality ball joint like this one that also help move the rod backwards a little.http://store.rc4wd.com/M3-Offset-Sho...0x_p_1741.html
#2 No not at all. tested that long ago. i does not matter if there is a bit of play on the stub axle. The solution is to increase the caster angle a few degree that will do a lot more improvement of running in a straight line. One other thing is to replace the plastic hub to a metal one. some of them brake easy where the servo arm connect . It seems this trucks need to have a bit of strange play to run well. and trust me i hate when things have play and look strange. but it works well.http://www.ebay.com/itm/252101908437...%3AMEBIDX%3AIT
