Old 01-14-2017, 09:30 PM
Northern Farmer's Avatar
Default Re: Stahl dozer gear boxes and drive motors
Also found this, I'm not sure if it would work on your Stahl dozer ?
http://store.rc4wd.com/DXR2-Dozer-Dr...et_p_5124.html
Old 01-14-2017, 11:12 PM
rc13's Avatar
rc13 rc13 is offline
Hi again, another great suggestion. Those motor drive sprockets look great. I am sure plenty of power. They appear that they might mount up. For sure the sprocket teeth are way different, so I would have to mount mine to that motor set up. If I could only see what that looked like with the sprocket off....
Hopefully I can find another solution for a lot less that the 500 USD.
Thank you so much......
