Old 01-16-2017, 01:01 PM
Stuart's Avatar
Stuart Stuart is offline
Stuart is on a distinguished road
Default Re: Parkinson Heavy Haulage
Wow thats awesome! I'd be interested in a couple of the lighting arrays if you were to produce them, could you please explain the function of the Arduino nano in the building?
Cheers
Stu
Old 01-16-2017, 02:08 PM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Hofabooz is on a distinguished road
Cheers
Stu
Hi Stu
Thanks for your positive comments.
The Arduino Nano is there to process the command form the infrared remote control.
You can switch the left or right lights and the beacon on the building on or off independently.
Future expansion will be the remote operation of the door and possibly some sound effects and a display screen or clock.
the two light towers also operate form the same remote though of using Bluetooth or a spare radio set but that would have meant carrying a phone or transmitter around and the simple remote or even a tv remote could be used is small and has loads of buttons so win win.
I will think about producing the light towers I will just have to refine them a bit further first
Many thanks
Mark
Regards
Mark
Over the Pond in the UK
Member of Ribble Valley Radio Controlled Truck Club
my weather station
Old 02-15-2017, 01:38 PM
Stuart's Avatar
Originally Posted by Hofabooz View Post
Hi Stu
Many thanks
Mark
Thanks for the explanation Mark, so is there an arduino in the light tower aswell?
I'm really getting into the arduino range of stuff, after seeing your post I ordered a starter kit, its awesome!
After a couple of hours of head scratching and watching tutorials I created a thermometer with lcd display, the possibilities are endless!
My plan now is to make a system to fit in my digger with a small oled display in the cab which shows volts, amps, temp & oil pressure then sends that info to my taranis as telemtry a bit like the brixl system only a fraction of the cost.
Running before I can walk I know and the coding is going to be a nightmare but we'll see....
Waiting for oled & volt, amp & pressure sensors to arrive.
Stu
Old 02-16-2017, 04:34 AM
Hofabooz's Avatar
Hi Stuart
You read my mind that is just the route I have thought about taking.
Yes there is an Arduino nano in each light tower a relay and a infa red receiver
We should compare plans sometime soon we may be of help to each other in this endeavor.
I too an new to Arduino and just finding my feet so to speak.
I dont have any hydraulic equipment yet however I plan to develop the same type of system for telemetry.
many thanks
Regards
Mark
my weather station
Old 02-16-2017, 11:00 AM
Stuart's Avatar
Hi Stuart
many thanks
How freaky!
That would be great, I think 2 heads will certainly be better than 1, I can't see it being easy.
I have found the code for sending the data via the s-port to a Taranis so thats a start.
I'll let you know when my parts arrive and I can start assembling the H/W side of things and look forward to working together on it.
Cheers
Stu
