Old 01-27-2017, 05:29 PM
Default Re: Led help please
Check out the All about Led thread at the top.
You're probably going to want to split the truck into parallel circuits of 5 or less lights. Make a bus out of anode and cathode sides, throw 1 resistor on the power side going to each of those.
The 10 rear lights i'd split to 5 right, 5 left each circuit with limiting resistor and run them in parallel off the same switch.
Cab i'd put the 5 roof on one, 3 sides, other 3 sides. You may have to tweak resistor values some if you're not happy with how even brightness is between top and sides.
If you are working at normal RC recciever voltage(7.2v stick pack going into an ESC with a BEC for 4-6v output), a 150 ohm or greater LED will safely get your LEDs working. You won't get peak output, but it gets your unknown lights scavanged off something going without freeing the smoke. Also no math if you go 150 ohm to 450 ohm resistors
If you are running red and white leds together on an output like head & tail lights: Make a red circuit and a white circuit. the red need a bit higher resistance or the whites won't work. So my 150 ohm goes on the whites, red gets something 200-400 ohm to start with.
