Old 02-08-2017, 03:08 AM
Northern Farmer's Avatar
Default Re: 870k loader or ??
Originally Posted by liftmys10 View Post
I did a search on this forum for the wa500, only one person posted a build thread on it from germany. Maybe one other person has one. It does look great. I'm thinking of adding one to compliment my pc700. Any other info on the wa500?
"As already known from other Fumotec models, this wheel loader is built from solid TIG welded steel frame parts. The 4 brushless drive engines result in an easy to modulate and high performance drive that is second to none. The hydraulic unit included in the assembly kit is very effective and powerful, already at a working pressure of only 14 bar. Therefore, you will receive a high performance model which combines approved technology and innovative ideas to fulfill the guiding principle: Fumotec – moving more!"
Technical Data:
Length: 705 mm
Width: 230 mm
Height: 270 mm
Scale: 1:14
Weight: 14 kg
http://www.fumotec.de/englisch/model...00-6/index.php
https://www.facebook.com/fumotec.de/?ref=page_internal
